Board index Do you have a BIOS problem? Notebook BIOS and other problems Need the complete bios driver
Post Sun May 06, 2012 11:23 pm
markantoun New visitors - please read the rules.
appreciate if anyone can help me find the complete bios driver for hp-mini-110-3130se because the lap-top can't even start and all that i could find on hp site is only its UPDATE.
thanks in advance.
Post Tue May 08, 2012 1:59 pm
edwin User avatar
If the laptop does not start this is usually because of a hardware problem. The updates given on the HP website are complete bioses, it's just a newer version:
http://h10025.www1.hp.com/ewfrf/wc/prev ... 4&sw_lang=
The only thing you need to do is unpack 2 times until you get the .fd file that is the actual bios file.
Insyde bios recovery instructions:
http://www.bios-mods.com/bios-recovery/ ... -recovery/
Good luck.
0148A.zip
Insyde bios file, unzip to 0148A.fd before using the recovery method to flash it.
(1.13 MiB) Downloaded 109 times
Return to Notebook BIOS and other problems
  • Related topics
    Replies
    Views
    Last post
