Board index Do you have a BIOS problem? My motherboard is dead Compaq Armada E500 bios dead
Post Wed Jul 24, 2002 5:05 am
werboga I didn't read the rules
Bios update went bad even though update program said it was ok. Now just sits there with three lights on. Only thing that comes on is fan. Nothing else. Does this thing have boot block recovery pads ? If so, where on the board are they? If not, any other way to boot to floppy to reflash bios? I know some other laptops use a parallel port plug to activate the boot block. Thanks for the help.
Post Sun Nov 24, 2002 3:51 am
Joe Chip off the ol' block
Take a look on the bottom of the laptop below the RAM expansion cover, there may be something there..
The presarios have them here and the Armada's might as well..
Joe
Return to My motherboard is dead
  • Related topics
    Replies
    Views
    Last post
