Board index Do you have a BIOS problem? RAM compatibility with BIOS POST Reports Memory: OSs can't see it. SiSandra Sees SIMMs
Is your memory not fully recognized? (Intel VX chipset Memory recognition)
fairyliquidizer New visitors - please read the rules.
Last edited by fairyliquidizer on Thu Mar 30, 2006 8:12 pm, edited 1 time in total.
HEEEELLLPPP!!
I'm trying to make my dads PC a better machine so I decided to format the HDD and install a fresh OS and firewall, AV etc.
Well then I discovered that he only had 32Mb in it. So I bought some PC100 installed it and ehm the BIOS sees it but windows doesn't soooo.... I gave up on Win 2k and dug out and cleaned up my old NT4 CD and it only sees 32Mb, and if I take the old 32Mb SIMM out the BIOS sees the 128Mb or 64Mb SIMM (I have a 128,64, and 32 and 2 slots) but windows says "0k base memory need 512k to install".
Tried PC Linux OS (as it's a single CD and theres no DVD ROM drive in the machine) but it wont boot! The installer does manage to load the kernel even with just a single 128Mb SIMM installed.
Ideas please. HP BRIO BA Model D7594A Celeron 433
I downloaded the "latest" BIOS from the HP site "HX 07.08 QHX.08.00" Phoenix BIOS 4.0 Release 6
Is there some generic BIOS I can flash on the board instead? The POST reports all memory but OSs don't see any more than 32Mb!
Help me please :)
Fairy
Post Mon Mar 27, 2006 11:34 pm
Hmmm the working 32Mb Modules are 4Mx64 and the non working 128Mb module is 128Mx4 ....could this be the problem?
Post Tue Mar 28, 2006 2:01 pm
KachiWachi User avatar
The New Guy
D7549A or D7594A?
Post Thu Mar 30, 2006 8:12 pm
D7594A sorry I'm a little dyslexic so it's tricky for me to write things in the right order :-D
Post Fri Mar 31, 2006 3:32 pm
The New Guy
PDF lvp08047 says this machine comes with 64MB SDRAM 100MHz, and they offer kits ranging from 32->128MB non-ECC, and a 256MB ECC kit.
SiS 620 chipset?
Post Sat Apr 01, 2006 12:23 pm
I've found the solution... I bought some more memory this time x64 type stuff and it works fine. I only bought another 128Mb which isn't a lot but I've spent enough on this especially as my dad never uses his PC! He just wanted a nice clean working install and he finally has it :)
Thanks guys,
Fairy
Return to RAM compatibility with BIOS
  • Related topics
    Replies
    Views
    Last post
