#46902 by jawz01
Sat Dec 01, 2007 4:32 pm
I am haveing a problem getting my motherboard to recignise my HardDrive(40GB) at boot up it says finding the HDD (press F4 to skip) and it stays like that for hours. but if i put the jumper to cable then it will find the HDD but will not move to the boot screen at all. If i put a 8GB HDD in the computer it will work fine I need help to sort this out if any one has ANY suggestions then can you place them here please as i have spent the last 4 days working on this.
the computer specs are:
The pc is a Time pc
The mobo is a FIC MPV4 VIA APOLLO
Bios type:award modular bios v4.51pg
Bios date: 10/15/99
Bios ID: 10/15/99-MVP4-686A-2A5LHF0AC-00
OEM SIGNON:VERSION SA411G5 TIME COMPUTER SYSTEM 382MO2GB
SUPER 1/0 VIA: 686 REV 27 FOUND AT PORT 14H
CHIPSET VIA:82C501 REV 2
CPU TYPE:AMD-K6(tm)3D PROCESSOR :?
