My last battery is broken, and i have bought a new one, the detail: <link removed, it's a Dell battery> , i used the battery for the first time and have some questions here. I wondering whether i should remove the battery when using AC, i try to search for help on google, it turned into many results, someone said yes while some other said no. Both of them claimed their views are reasonable, what should i do to avoid destroying the battery?
any thoughts?
charge way for my new laptop battery?
If the battery should be removed during AC they would have made it a lot easier to take it out (on the front or something). Leave the battery in when using AC. What you can do is only connect the AC when the battery is almost empty.
