my current HD is only 17GB and i want to buy an extra 40GB.
can i simply replace the old one ? Because the older one has in-built windows ME but i use XP now ?
Would this cause any problems ?
Question about HD...
Well atm i hav a 17GB HD with windows ME inbedded onto it in a hidden partition.
If i was to replace this HD with a 40GB one would i just have to format the new one with XP ? And no problems would ocour ?
I'm a newb at overclocking so expect some dumb comments
questions-
Is this an OEM system? If so please post the complete model/series info.
How do you know the 40GB drive will hook up without trouble? (i.e hard drive barrier, etc.)?
Compaq-Fu Master
