Hi, everybody.
I need your help.
I have installed a new hard disk in my computer, it's installed like primary slave. Computer starts correctly and
show me the name of new hard disk. Well, my problem is this, the hard disk has size of 180 GB, computer recognize
130 GB only. How can I do?. Someone said I have to upgrade BIOS, but I have been looking for the last updated and
I don´t find it. I send information about my computer.
Thank you very much.
BIOS Date: 09/28/01
BIOS ID: 09/28/2001-i845-W627HF-6A69VM4GC
OEM Sign-On: W6534M7 V1.0G 092801 23:38:00 MEDIONPC
Chipset: Intel 1A30 rev 3
Superio: Unknown
OS: WinXP
CPU: Pentium 4 1700 Mhz MAX: 2400 Mhz
BIOS ROM In Socket: Yes
BIOS ROM Size: 256K
Memory Installed: 256 MB
Memory Maximum: 3072 MB
Memory Slot 01: 256 MB
Memory Slot 02: 0 MB
eSupport.com, Inc.
1-800-800-BIOS (2467)
www.esupport.com
Hard disk problem
Microstar MS-6534 for Medion PC.
Latest BIOS update:
W6534M7 V1.52 111302 18:05:00 MEDIONPC
11/14/2002-i845-W627HF-6A69VM4GC-00
http://www1.medion.de/downloads/downloa ... xe&lang=de
Latest BIOS update:
Even if the new Bios still detects 130GB your OS - Win XP - should be able to adress all remaining space above 130GB if you have at least SP1 installed.
For more info visit www.48bitlba.com
