Tkx again,
It works fine ussing Pflash.
But the flash dit not what i was hoping.
It is a bord that islimited at 166 Mhz CPU, on a socket 7.
I do have a AMD k6/2 350 Mhz, and wa shoping that there is a way to make it work on a bord P/I-P55TP4N
the latest bios i can find is the 0302.
Is ther something newer that may help me?
And a ùmanual where to see for jumpersettings
Greetings
20GB: 10/27/1998-SiS-5600-2A6ILV3EC-00
Try http://wwwbzs.tu-graz.ac.at/edv/prodinf ... 55tp4n.pdf for the manual.
There is nothing in the manual about jumper settings for 2.3-2.8 volts Vcore. I do not see how the board will support K6-2 electrically without modification.
Ok, then i think that i should rest my case and try to find a way to make a chance 72 pin ram memory into 186 pc 2100 or pc 133 ram memory.
I will search for a forum where a can make this kinda barge.
I will try to make an offer in the way of 1.5 mb for 1 mb in return.
Greetings
Greetings
