I need a bios patch on my system. The bios data are:
BIOS ID: 01/25/1999-691-586B-W877-2A6LFJ1CC-00
BIOS Eval: V.791BS_2 B04
Any help is very much appreciated.
Thanks.
40GB for 01/25/1999-691-586B-W877-2A6LFJ1CC-00
It's a Jetway motherboard, but there are more 'owners':
http://www.supportbios.info/resultado.a ... &Idioma=EN
Thanks for the replys. I checked the bios from jetway's site and the Bios Type, Bios ID, and Bios Eval as well as the manual are the same with mine. I haven't tried yet the others. Anyway, I used the utility by Rom.by and it now detects the 40GB HD. Any reply is still very much appreciated.
Regards
Regards
Congratulations - I'm glad it worked. Sometimes in the past when I have updated a BIOS and was not 100% certain myself that I had an exact match, but just had the closest match I could find, I also felt like I was taking a bit of a gamble. But I always backup the old version with the flash utility to give me a better chance of recovery if needed.I checked the bios from jetway's site and the Bios Type, Bios ID, and Bios Eval as well as the manual are the same with mine. I haven't tried yet the others. Anyway, I used the utility by Rom.by and it now detects the 40GB HD.
Do you need any furher help? If you install a larger HDD in the future (>64GB) it would be interesting to for your to report whether it works with that or not.Any reply is still very much appreciated.
Thanks for the replys again. Anyway, I did not use the bios from jetway's site but instead I used this patching utility by Rom.by. I patch my bios using this utility and now my pc detects the 40Gb capacity. After patching, the utility said it could detect until 137Gb HD. Since then, I did not notice any problem on my pc after installing the OS and etc. Any reply is appreciated.
Regards
Regards
The only suggestion I would make is that next time you patch a BIOS yourself (and you may have already done this), patch the latest BIOS you can find from the manufacturer.
That way you get all the latest hardware support, features and bug fixes, plus what you patch. And sometimes the manufacturer BIOS may not require patching, if it already gives you the HDD support you require. It is best not to patch if you can avoid it.
