8.4GB+: QDI P5I430VX-250DM Explorer II
joe riverdale
8.4GB barrier on a QDI P5I430VX-250DM Explorer II
The Specs:
BIOS Date: 03/13/97
BIOS ID: 03/13/97-i430VX-NS306-2A59GQ1EC
OEM Sign-On: P5I430VX-250DM Explorer II BIOS V3.4S 03/13/97
Chipset: Intel Triton rev 2
Superio: NSC 306 rev 11 found at port 398h
OS: Win98
CPU: P55C 233 MHz
BIOS ROM In Socket: Unknown
BIOS ROM Size: Unknown
Memory Installed: 63 MB
Memory Maximum: Unknown
The QDI website: www.qdigrp.com only mentions Y2K and others flashes. Is there a third party or similiar i430VX burn I can try? I am presently using a Fujitsu 10.2GB with diskgo (DDO) but with a dual boot with linux it will create problems. Unless there is Linux fix for this. Any feedback/help would be greatly appreciated. CAN I FLASH THIS BIOS TO USE A LARGER THAN 8.4GB drive?
Thanks in Advance.
Joe Riverdale
BFC - Bottom Feeding Computing (copyright 2005) at it's best..*g*...on a big medical/financial turn around and just trying to get up to speed.
