Ad blocker detected: Our website is made possible by displaying online advertisements to our visitors. Please consider supporting us by disabling your ad blocker on our website.
durimi
Posts: 5 Joined: Thu Jul 22, 2004 6:57 pm
Thu Jul 22, 2004 7:01 pm
Hi
I have bougth an 80 GB Maxtor hard disk but its recognized as 32GB what can I do .
The bios agent result are :
Program: Unicore BIOS Agent Version 1.9
BIOS Date: 07/01/99
BIOS ID: 07/01/1999-692-596-W977-2A6LGM4EC
BIOS Eval: VMP 1.0B6f * MSI MS-6163VA
Chipset: VIA 82C597 rev 34
durimi
Thu Jul 22, 2004 10:45 pm
thanks for help but it don't works have some one any idea
BIOS Guru
Posts: 3153 Joined: Thu Mar 21, 2002 8:16 pm
Fri Jul 23, 2004 7:02 am
Remove the 32GB Limitation jumper from your HDD !
durimi
Fri Jul 23, 2004 12:53 pm
When I use awdflash to write memory when it finish it becomes an error that says that the destination patch isn't found
BIOS Guru
Fri Jul 23, 2004 4:06 pm
Sounds like a bad flashprog or filename was typed wrong .
Use Uniflash for flashing !
-> Biosfile is compressed in ZIP-format - you have to decompress it first !
durimi
Fri Jul 23, 2004 5:11 pm
Let says that it was the awdflash utility problem so I have write with the uniflash so thankyou everybody.
Ritchie
BIOS Guru
Posts: 761 Joined: Wed Oct 30, 2002 5:17 am
Sat Jul 24, 2004 10:41 am
So does this mean you have now sucessfully flashed using UniFlash and are now able to correctly detect your hard drive?
durimi
Sat Jul 24, 2004 2:48 pm
Yes now its possible to use my hard disk in full capacity thanks to all of you.
