HD Samsung HD103SJ; Motherboard Asrock P4V88
The above motherboard is not recognising the above hdd. The latest bios of motherboard was flashed and also since there is a known issue between the SATA 3 and 1.5 I had flashed the hdd with the samsung software to fix that issue but still when I tried to install the win XP hdd was still not recognised. Any solution please?
HD Samsung HD103SJ
http://www.asrock.com/mb/overview.asp?Model=P4V88
XP needs a separate driver from a floppy disk during install for the mass storage controller on your motherboard:
http://www.asrock.com/mb/download.asp?Model=P4V88&o=XP
or set SATA mode to non-RAID:
http://www.asrock.com/support/faq.asp?id=140
