After installing SP1 on WinXP Pro, and all the security updates I just came upon a very weird situation: whenever I right-click a link and select the "Open in new window" command, a new window appeares, but on the address bar there is nothing, and it appeares as if it tries to open the page, but that never happens. if I press ESC, the address appeares in the address link (bar) and I can see the page if I press the refresh button.
This abnormal behaviour also happens when I click on a link in the Outlook Express
I have eDonkey installed, as well as some other programs that came with some adware software, but I was using them for a couple of months before and everything was just OK.
I can open any web page in the normal way, by typing the address, or by left-clicking a link.
Please tell me how can I get the IE6 back in working condition. (the OPEN IN NEW WINDOW stuff).
IE 6 problem. Please help
Do you have all the Internet Explorer updates from Windows Update installed?
