#10810 by yhnl4
Sat Nov 09, 2002 8:14 am
#10810 by yhnl4
just recently i have flash my bios with a newer or older one(i'm abit confused on the version). The comp would just froze at the very beginning
and i can't go in bios setup. I've cleared cmos and took out the battery but even that failed.
I have a GA-6BXE revision 2 mobo by gigabyte & 2Mbit Award bios
PIII 600mhz
128 SD ram
heres the site for bios update
http://tw.giga-byte.com/support/intel44 ... m#link6bxe
now my questions are:
1.how do i know which bios version to download when you have flashed the wrong version in 1st place?
2.do i flash the bios updates one by one or just the latest one?
3.does my bios have boot block?
4.does the boot block method really work?
thanks in advance
