i tried to update my bios using awdflash.exe i have got from http://www.unicore.com/. during the installtion i was asked to enter a file path wich i didnt have and i just left it empty. since then my computer dosnt work, black screen and strange beeps one lone beep and two fast short.
my bois information are:
bios type:Award modular bios v4.51pg
bios date: 06/11/96
bios id: 6/11/96-i430vx-2a59gz19c-00
oem sign-on:5dvx ver:1.0 1/07/96
super i/o:vmg/itc 8669 rev 0 found at port 108h
chipeset intel triton 430vx rev2
os: ms win98se ver 4.10.2222a
cpu type p54c 132 mhz
bios rom in socket
memory installed 47mb
thaks for your help
my pc is dead
Use this BIOS here:
http://mobokive.dyndns.org/Archive/Zida/bios/5dvx/
...to revive your system, but read our recovery techniques first.
hi again
here is what i have done and im still having the same symptoms
1. bootable DOS diskette image from www.abitfaq.it/Files/drdflash.exe .
2.Use this BIOS http://mobokive.dyndns.org/Archive/Zida/bios/5dvx/ .
3.wrote an autoexec.bat file
@echo off
cls
awdflash 5DVX_19U.bin
but still having the same problem, black screen , one long beep followed by two short.
@echo off
cls
Does it really boot from the floppy? Try UniFlash: "uniflash -e 5dvx_19u.bin".
Probably not the best place to ask this (pardons to the thread author), but I've seen this here before...someone doesn't put in a filename to flash, and the board is dead after AWDFLASH exits. What gives here? Is AWDFLASH actually doing something then and not quitting gracefully, thus destroying the currently installed BIOS??
