ECS P4M800PRO-M478v1.0
JEWilson
Chip off the ol' block
Board Recd Dead
Found dead battery - replaced with new one.
Updated BIOS to most recent with a Willem.
Installed a PCI POST Card
1
Using a X-Power ATX 24 pin 500W PSU
When not powered on but POST Card in PCI Slot
Only 1st POST segment is lit - shows 8 not flashing.
When powered on but POST Card in PCI Slot
All 4 POST segments lit - all show 8, 1st flashing
When powered off but POST Card in PCI Slot
All 4 POST segments lit - all show 8, none flashing
On the POST Card when 1 as above, the clk iow, rst, +12V and
+5V LEDs only are lit - +12V barely
2
Using a standard ATX 20 pin 350W PSU
3
Using the standard ATX 20 pin 350W PSU with 20 to 24 pin adapter
On the POST Card when 2 and 3 as above, the sys LED and
+5V LEDs only are lit - Is this a 5VSB issue?
I have been advised as to PSU swap out prior to.
Any suggestions?
Have you got a non X-Power recent power supply anywhere?
JEWilson
Nothing more recent than a Magna 600W 20 pin ATX
Also have a dated QTEC 20 pin ATX
http://www.qtec.info/products/product.htm?artnr=13023
Haven't tried these yet
