hot flash PLCC
notinthisworld
BIOS Rookie
hi,
is it possible to hot flash PLCC bios chips?
thnx
God Bless
cp
BIOS Guru
sure. they are the same as normal dip flash chips (at least inside). it will be a bit more risky to remove them from their socket while the system is full up and running but once the chips are swapped..
notinthisworld
BIOS Rookie
ok thnx very much
God Bless
