No POST
cuervo1
I am looking for information on a K8N-DL Motherboard that will not POST. I sent the board to the Asus RMA Dept. and they report that the board is O.K. I am testing it with a minimum of Hardware which I believe is: Video:Getforce 6600 D256M :Processor Opteron 240 in socket #1 Memory : 1GB PC3200 DDR40 ECC REG. in Socket A1: Power supply is Antec EPS True550 12 Volt 550 Watt. All voltages checked with voltmeter.
I have two Matched 240 Opterons and have tried both , I have two of the Memory modules and have tried both in this configeration. Neither will post. Assuming that the RMA Dept is right thenI have two bad Processors And-or two bad memory modules. What is the cheapest Processor and memory that I can buy to prove this theory? What do you recommend as the best way to trouble shoot this board?
Thanks,
B.K.
See this first:
http://www.motherboards.org/forums/view ... hp?t=39873
You'll pretty soon see what the problem might be. Ask Asus what CPUs/memory/power supply they used to test your board with.
