This is faisal, i'm having problem with my system bios
(-i815E-627-6A69RFGDC-00, BUILD DATE:03/01/2001, FLASH TYPE: SST
49LF002A/3.3V)and i'm really in trouble now.The version of bios i've i
feel that its having problem with my 80 GB seagate harddisk.In other
words it is not dealing fairly with the harddisk.It changes the drive
geometry also, when i formatted the C drive then there was nothing
after booting.All partition i've i lost them.
The request is that kindly identify my board manufacturer and if
possible then kindly give me a bios upgrade.I've visited your
website it is brilliant and significantly help full for beginner and
other advance user.
Waiting for an early response.
Thanking you
faisal (Karachi)
Need help and update for -i815E-627-6A69RFGDC-00
There are three motherboards with that string.
Can post complete BIOS ID?
Run BIOS Agent for it:
http://www.unicore.com/biosagent/index.cfm
Hello Kuriaki,
I vistied your website u r the man its really appreciatable and helpful also for those who cant afford replacements in thier system timely like me (lol) they can also use new hardwares by updating the bios only.
Any way thanks to reply.
Thanking you
Faisal (karachi)
Thanking you
Faisal (karachi)
Hello Kuriaki,
I vistied your website u r the man its really appreciatable and helpful also for those who cant afford replacements in thier system timely like me (lol) they can also use new hardwares by updating the bios only.The bios details are as under:
BIOS Date: 03/01/01
BIOS ID: 03/01/2001-i815E-627-6A69RFGDC
OEM Sign-On: Release date:2001/03/01 Ver:2.10
Chipset: Intel 1130 rev 2
Superio: Unknown
OS: WinXP SP2
CPU: Intel Celeron(TM) 800 Mhz MAX: 1500 Mhz
BIOS ROM In Socket: Yes
BIOS ROM Size: 256K
Memory Installed: 256 MB
Memory Maximum: 512 MB
Memory Slot 01: 128 MB
Memory Slot 02: 128 MB
Memory Slot 03: 0 MB
Thanking you
Faisal (karachi)
BIOS Date: 03/01/01
Superio: Unknown
OS: WinXP SP2
BIOS ROM Size: 256K
Thanking you
Faisal (karachi)
Check my reply in the other forum.
