Sometimes, after a shutdown, my pc won't power on... seems that the signal from graphic card (Radeon 9200 series) never reach monitor.
Follow bios agent log:
Program: eSupport.com BIOS Agent Version 3.31
BIOS Date: 04/16/04
BIOS ID: 63-0608-000037-00101111-041604-Hammer-K8V-F037
OEM Sign-On:
BIOS Date: 04/16/04 14:00:06 V
Chipset: VIA 82C3188 rev 1
Superio: Winbond 697HF rev 2 found at port 2Eh
OS: WinXP
CPU: AMD Athlon(tm) 64 Processor 3000+ 5.1.2600 Service Pack 1
BIOS ROM In Socket: Yes
BIOS ROM Size: 512K
Memory Installed: 512 MB
Memory Maximum: 4096 MB
Memory Slot 01: 512 MB
Memory Slot 02: 0 MB
eSupport.com, Inc.
1-800-800-BIOS (2467)
www.esupport.com
thanks in advance, Luca
Power on prb: 63-0608-000037-00101111-041604-Hammer-K8V-F037
I was working on one system with a hardware conflict. Without a certain card present, system would power on every time. With the card present, you had to wait at at least 15 - 20 secs after power off before powering back on, otherwise a similar problem to what you are describing.
Does your system follow these kind of rules?
yes,the behaviour is similar,but this happens sometimes... I can't try w/o radeon cause i haven't another card and I was unable to change slot because mb has only 1 agp slot; plugged in a pci slot there is a network card, but i doesn't try w/o it.
I think that's all.
Thanks, Luca.
I think that's all.
Thanks, Luca.
