Hi I need a vga driver update for my chipset graphics.
The latest one I have injected is 1 version ahead but is of the generic intel developers site and I havent got the time to find it.
I can extract it out of another manufacturers award bios because I have compared 3 different companies "optimised" drivers and they are quite literally identical and are 1 version behind.
Build Number: 2682 would be nice thx.
i think a more accurate description of the driver would be the actual vga bios since it controls the chipset graphics from the system bios.
BTW the generic one is bulky and flickers the screen on cold and warm post.
I815E VGA
Such huge landfill new tech costs when all we need is scaleability.
There are no "optimized" drivers available - all manufacturers use the generic drivers from Intel .
Maybe there's a problem with your VGA-Bios and the new Intel drivers
Try to get an updated mainboard Bios and hope for a newer VGA Bios to be installed inside .
well there isnt really much prob with it except the quick flickering before post beep so i dont think theres a real issue.
I thought there'd be a more optimised version cause the previous was much smaller size and the code seemed a lot more organised.
Its just the vga bios binary I wanted I have the latest drivers for windows.
I really gotta work on my communication skilss lmao
