ok i have a NVIDIA RIVA TNT2 Model 64/Model 64 Pro and im having trouble with the new deternator drivers wont work keep on wanting to install itself every time i reboot would a video bios update fix this and if so help me find out were to get it and do it please note that the diver file mentioned is the newest one it will accept
Video Adapter
Model : NVIDIA RIVA TNT2 Model 64/Model 64 Pro
Total Memory : 32MB (32MB Video) (56MB AGP)
Texture Memory : 88MB
Supports DIME Texturing : Yes
Hardware Revision : 021
Current Video Mode
Video Mode : 1024x768 16M+ TrueColour (32-bit)
Refresh Rate : Default
Supported Refresh Rates : 60,70,72,75,85,100,120,140,144,150,170Hz
Video Driver
Model ID : nvdisp.drv
Version : 4.12.01.618
Supported Windows Version : 0.1024
Video Acceleration : Yes, All Functions
Screen Saver Active : No
Low Power Saving Active : No
Power Off Saving Active : No
Video BIOS
Release Date : 06/15/99
Version : 2.05.13.03
VESA BIOS
Version : 3.00
VESA VBE/PM Version : 1.00
Manufacturer : NVidia
Video Adapter : Riva TNT
Adapter Version : B1
OEM Chipset BIOS : NVidia
OEM BIOS Version : 2.05
Total Video Memory : 4MB
Current Video Mode : 03h
Linear Frame Buffer Address : 3680 - 3684MB
- Absentee administrator
A BIOS, if one even exists, won't help you. You just have to accept the fact that as nVidia develops drivers for their new chips, the old ones will develop incompatibilities.
Just use the last version that worked for you, and stick with it. It's not going to make a performance difference anyways.
I'm using a TNT2-Pro with 30.82 drivers and had no problem installing them .
Maybe your drivers have some installation problems .
De-install your drivers if possible or use detonator destroyer or other utilities to get rid of them .
Please get working drivers before you delete the old ones .
I had mine from www.guru3d.com
