could someone help me with a patch for this BIOS? AsRock support is non-existant, and after updating everything on the machine I have found the "VBIOS" as SIS calls it, is still at 1.11.29. I need minimum 2.28.00
Info from SiS
If your VBIOS version is not 2.28.00 or later, you have to update your BIOS, please contact your board maker or system provider to get BIOS update support
The board uses AMIBios and I can't chnge the vbios into AmiBios module.
Link to my oryginal Bios http://www.asrock.com/mb/from.asp?Model ... T=B&ID=237
I've 22" NEC AccuSync LCD monitor and I steel work with 1024*768, byt max resolution in 1680*1050 i avilable, but screen is steel white
Motherboard: AsRock GTe Pro-HT
Bios: AMIBIOS rev. 2.40
Adapter type: Sis_650_651_M650_M652_740
VBios: 1.11.29
Chip type: SiS 651
Driver version: 3.73 (there is 1680x105 resolution yet, but with white screen)
