Which flash-ROM for Realtek 8029 NIC?
Video, SCSI, modem, CDROM/CDR/CDRW, etc.
Tomasz
Chip off the ol' block
Hi! after long time...
Sorry Moderator, I do not know it is right forum for my question...
The problem is:
I have NIC Realtek 8029 with empty =28 pin= socket for flashrom.
I would like to make it as bootable NIC for my old comp... I have tried to get info from many www sites about flashroms, but no results - too many chips&info for me B-)))...
Which kind (type) of flashrom do I need to flash it with BIOS for NIC as I described it above?
Tnx for any advice,
Tomasz.
ajzchips
El cheapo dude
http://www.realtek.com.tw/downloads/dow ... True#14DOS
There are three bootroms included in the RPL Boot ROM program file, depending on whether the chip you find is 16KB, 32KB or 64KB.
Rainbow
The UniFlasher
The problem is to get a 28-pin flash ROM chip...
Tomasz
The first problem is gone! I found a shop with FlashROMs 28 DIP.
They cost ~2,5euro...
But the next:
-how to flash that chip..? into my NIC socket? Or into original mobo socket with "hot-flash"..? And it has 32 pins...
Tomasz.
The New Guy
My Intel EtherExpress PRO-10+ ISA card flashes right in the NIC socket, using Intel's program for this card.
Tomasz
Is it possible to flash chip with PCI CARD..? I would like to use my NIC PCI for that... with Uniflash..
Tomasz.
P.S. The flashROM chip is:
ATMEL 28 pin's DIP
AT28C64B
15PC
0250
Rainbow
The UniFlasher
AFAIK, there's a flasher included with the BootROM images at the Realtek site.
Tomasz
Any right link to Realtek site, please..?
That ATMEL chip is an EEPROM, isn't it?
It Could'nt be flashed via PCI card with floppy disk... or am I wrong?
Tomasz.
ajzchips
El cheapo dude
Link already given up above.
