I have a mb that the ps2 and usb does not work. is there any way to change settings somehow? I plug in internal pci usb card and its ok, boots to windows, everything fine. just can't change settings before bootup
thanks
Any way to change bios settings from dos/windows?
there must be a reason why the usb and ps/2 ports don't work. my guess: missing jumpers on the +5VSB/+5V headers, blown onboard fuses or burned inductors (if there are no fuses).
where did you get the board from? did you check the +5V voltage on PS/2 and USB ports? can you make a highres photo of the board and post it somewhere? (imageshack, ...)
