Computer will not boot
I have a Compaq 1716CL desktop PC. It has an ASUS A8AE-LE Motherboard. The BIOS is Phoenix award bios Core v6.00 PG Revision3.08 09/13/2005. My problem: Original OS was Win XP home, Original hard drive had 2 partitions, One was for OS, and one was a restore partition. When booting the screen would say press f1 for setup, f12 for system restore. Somehow I blew out the OS, and the restore didn't work. I upgraded the memory, and installed Windows 7 ultimate. I formatted the restore partition and used it for the page file. Computer would boot but had a error, cant remember what it was, but hit space bar, and boot would continue. Worked great. I bought a new hard drive, formatted it, installed Windows 7 on it, and used orig drive for data and 'restore partition for page file. Still had error on boot but it worked. Decided to reinstall windows 7, I deleted both partitions on original drive, and made one big partition. Booted from Windows 7 DVD, Re-installed OS on C drive. When computer rebooted, it ran POST cleared screen and froze with funny characters in upper right corner. I think the BIOS is looking for a partition that no longer exists, and is locking up. What do I do? Can I change the BIOS, and how would I do it?
I can boot from DVD, just not from hard drive. The problem started when I deleted the old restore partition on the original drive. Can you find me a non-hp bios that is compatible with my Motherboard? Please.
This is not a windows error but a hardware error that shows now you are putting some real strain on the system. Check your hardware first, the symptom I am describing is fairly common for this board. BTW there is a commercial non-HP bio for this one, but it costs money.
Sounds like he was talking about an eSupport Bios. On top of the forum there's a green button named "Bios Update Scan". If they have a Bios for your machine then it would appear after running the Bios scan tool. Whether it's worth the money or not is the other question.
Edwin,
Motherboard Specifications, A8AE-LE (AmberineM)
Motherboard description
• Motherboard manufacturer's name: ASUS A8AE-LE
• HP/Compaq name: AmberineM-GL6E
CPU/Processor
• Socket: 939
• Supports the following processors:
• AMD Athlon 64 X2 4800+
• Athlon 64 4000+
• AMD Sempron 3200+
I currently have the sempron processor, but can I upgrade my processor to the AMD Athlon 64 X2 4800+? The CPU socket will accept it, but will it work with my motherboard? Also, can you e-mail me a copy of the 3.14 bios? Please?
CPU/Processor
• Socket: 939
• Athlon 64 4000+
• AMD Sempron 3200+
I'll check on the CPU, will email the bios once I have my desktop running again, as the motherboard has blown a capacitor (oh the irony...).
