Hi Dear Friends i hope you are all fine..!
i have three questions..!
!st is:
Friends i am using Unbranded System..!
and My Motherboard name is Intel intel d865 glc/peso/prc
My Motherboard cannot show Hyper Thread Technology option in Bios
My Processor is Original Intel Pentium 4 (2.6)
i wana show Hyper Thread Technology In My Motherboard..!
i too many search in my motherboard bios but i cannot see like this option...!
I see many branded system (Dell,IBM,HP) that have intel d865 glc/peso/prc motherboard and Intel Pentium 4 Original Processor,,but he show Hyper Thread technology option in bios...
2nD is: My motherboard intel d865 glc/peso/prc is original Intel Motherboard But When i start my computer then during Bios he Appear RM Logos...!
i will update my motherboard bios to 2005 but problem not solve and RM Logo still appear on my Computer During Starting bios
3rd: how can i upgrade my intel d865 glc/peso/prc motherboard Bios to Dell,IBM,HP,Bios?
Pls Help Me thx
Intel D865glc Bios Now Appear Hyper Thread Technology
There are 2 different 2.6GHz Pentium 4 processors.
One with 400MHz FSB:
http://ark.intel.com/products/27442
One with 800MHz FSB:
http://ark.intel.com/products/27494
The 800MHz FSB variant is used in the Dell/HP/IBM systems, your box which is very budget most likely, is using the older 400MHz FSB which does NOT support HT. So, it is not a bios problem, you just have a processor that has no HT in it.
DON IS BACK
ok thx for reply
but i used intel pentium 2.6ghz 800 bus speed prcoessor but Hyper Threading Technology option not appear in bios and problem is same
also tell me how can i show intel original logo during started computer,,currently RM Company logo appear during started computer
Dear Sir,
Your system motherboard was delivered by this company, please contact them for further support:
http://www.rmeducation.com/uk/
This is NOT a retail board from Intel so there is NO support from Intel and you can NOT flash the Intel bios on this board.
DON IS BACK
But Sir Intel all original Drivers (VGA,Sound,LAN) install correcntly on my motherboard
but only problem is that DUring bios appear RM Logo
give me any way or solution through which i will change my board logo
Download CPU-Z and report back with its output.
The Intel drivers will install fine on your motherboard - just like on any other motherboard that uses an Intel chipset - because it uses an Intel chipset! It doesn't mean that Intel supplied anything else but the chipset for the motherboard.
