My elderly neighbour has a motherboard with AB-SM5 -A on it ..which I assume to be an abit SM5a on abit site it says to flash using awdflash with file it5v5
when I try to flash message comes up file is wrong for hardware flash failed....wot am I doing wrong..cannot find other file on abit site.
please help this bios flash virgin with neighbours old PC
thanks
Roy
please help
Does the board have "2A59GA1FC" or "2A59GA1EC" in BIOS ID string?
The latest BIOSes are:
01/21/98-i430VX-Ali5123-2A59GA1EC-CP at ftp://ftp.abit.com.tw/pub/download/bios/sm5/it5vcp.exe
and
09/08/97-i430VX-Ali5123-2A59GA1FC-4Y at ftp://ftp.abit.com.tw/pub/download/bios/sm5/sm54y.exe.
If you're looking for big HDD support, we can patch one of these BIOSes.
and
Hi
thanx for reply, I tried both of these files..I am not only looking for large hard drive support I want to fit a cyrex m11 300mhz chip multiplier only goes to 3.5 at present which is 3.5 x 66 I believe 233 not 300
a Cyrix M2-300 does not run at 300MHz - usually 233 or 225MHz depending on version used - M2-300 is a speed grade compared to Intel Pentium .
Have a look what's printed onto the M2 - either 66x3.5 or 75x3 .
Latest FC Bios is CQ - same date as CP but 2A59GA1FC-CQ and not EC-CP
http://fae.abit.com.tw/download/bios/sm5-a/index-e.htm
First get the correct BIOS (E or F in ID string). Then get flash utility (older Awdflash or the latest UniFlash), boot into real mode DOS and flash.
So get the it5vcp file. It should support HDDs up to 32GB without patching.
Hi
tried again using that file with awdflash, I still get error saying "the program files part number does not match with your system"
at top it says " for i430vx-ali5123-2a59ga1ec- 02/24/97 flash type - m+1c 28f1000ap/ 12v
does the motherboard need chucking in bin
thanks again
Roy
thanks again
Roy
You get that error because the last two characters of the ID strings are changed (Abit used them to identify BIOS version). You can ignore the error. If the Awdflash does not allow you to continue, get another version or use UniFlash.
Have you used UniFlash?
