help
i have a problem with my onboard sound it is soundmax i have installed the driver and it is showing it as working but when i go to multimedia in win 98 it dosnt show any audio playback devices can any one help ???
im not sure but i am useing 98 se
Then forget what I mentioned previously. You may have to manually select the playback/record device from a dropdown menu in your Sound Properties. This may be necessary when your soundcard isn't configured as your primary/default playback device (i.e. when you have a modem with wave-out support, etc.)
welli tried that but its not there it says no audio devices
Are you installing the drivers that came with the mobo? Are you using generic drivers you downloaded from somewhere?
Why don't you tell us what motherboard you have...
the board is a atrend atc 7400 and its drivers i have gotten off the net i dont have the drivers that came with the board if you have any sugestions it would be great thanks
smcs lpc47m102 a9931-b7462 bh17251-7
Sorry, my fault, that wasn't your sound chip. That's your Super I/O controller chip. If you have AC97 sound, then your chip is most probably a lot smaller, but shouldn't be too far from your I/O chip.
How did you identify it as a SoundMax in the first place? Was this how the Windows Device Manager identified it?
You might have one of the chip models listed here:
http://www.mediatek.com.tw/english/site ... rivers.htm
when i did a add hard wear search that is what it came up with and the guy i bought it from who owns a computer store told me thats what it is
This board can have either Realtek ALC100 or Analog Devices AD1881 (called SoundMax). What's your BIOS ID string?
it is i810-47b27x-atc7400mc-ns
v1.x boards have BIOS strings like this:
09/10/1999-i810-47B27X-ATC7400MC-NS
ATC7400M Ver:1.0r03
v2.x boards with ALC100:
10/23/2000-i810-47B27X-ATC7400MC-KO
ATC7400M VER:2.1r01
v2.x boards with AD1881:
10/31/2000-i810-AD1881X-ATC7400MC-QT
ATC7400M VER:2.1r01
Don't know which chip was used on v1.x boards - the best way is to find it. According to Atrend, it's "U20 near PCI 1" for v2.x boards, hope that it's same for 1.x boards.
ATC7400M Ver:1.0r03
ATC7400M VER:2.1r01
ATC7400M VER:2.1r01
De-install old Sounddrivers and try the Realtek ones from here :
http://www.realtek.com.tw/downloads/dla ... tware=True
If they don't work too try Sisoft Sandra or AIDA32 or other tools to identify your Soundchip .
Or try AD1881 drivers from an Atrend mirror site :
ftp://ftp.univ-lille1.fr/pub/vendor/atr ... 000/SOUND/
>> large size driver
ftp://ftp.univ-lille1.fr/pub/vendor/atr ... nd/Analog/
>> small size driver
>> large size driver
>> small size driver
