Here's the situation. Downloaded a Win XP service pack. After it was installed the computer kept locking up. I was doing a restore to the previous day and the machine locked up again. Had to power off and now I have nothing. I have cleared the CMOS and replaced the battery. Sometimes I get the message "CMOS checksum errot" or "CPU unworkable or changed." When I hit DEL to go into BIOS all I get is a blue line across the bottom of the screen. I am running an AMD 2100+ on an Abit KR7A-133R mobo. I see now that the CPU is being recognized as a 1500+" and I didn't change it. Using Win XP Pro. Man I could use some help.
Thanks in advance
Can't get into bios
Blue line instead of SETUP - common thing on Abit boards. Usually caused by a fan connected to the board or an USB device.
golfer1250
Thanks for your reply...the only fan connected to the board is the northbridge and it is working....only usb device is the keyboard
I'd try disconnecting the fan and/or using PS/2 keyboard instead of USB.
