hi i have a m810lr mobo and a xp2000+ pro
my pc 4 or 5 times at day crash i try to find the problem with sandra 2003
i find that i must reduce the fsb speed but in bios i cannot change this settings if i have selected xp 2000 i can change only if i select 1250 mhz but i have a xp2000+ how can i solve this?
here are my configuration:
SiSoftware Sandra
Computer System
User Name : Luca
Logon Domain : LUCA-EE8TQYRHZX
Processor(s)
Model : AMD Athlon(tm) XP 2000+
Speed : 1.66GHz
Model Number : 2000 (estimated)
Performance Rating : PR2408 (estimated)
Type : Standard
L2 On-board Cache : 256kB ECC synchronous write-back
System Mainboard
Bus(es) : ISA AGP PCI USB SMBus/i2c
MP Support : No
System BIOS : American Megatrends Inc. 062710
System Chipset : Silicon Integrated Systems (SiS) SiS730 CPU to PCI Bridge
Front Side Bus Speed : 2x 133MHz (266MHz data rate)
Installed Memory : 448MB SDRAM
Video System
Monitor/Panel : Monitor Plug and Play
Adapter : SiS 630/730
Physical Storage Devices
Removable Drive : Unità disco floppy
Disk Drive : Maxtor 5T060H6 (57.3GB)
Disk Drive : Maxtor 91021U2 (9.5GB)
CD-ROM/DVD : PIONEER DVD-RW DVR-104 (CD 24X Rd, 8X Wr) (DVD 3X Rd, 1X Wr)
CD-ROM/DVD : AXV CD/DVD-ROM SCSI CdRom Device (CD 32X Rd) (DVD 4X Rd)
Logical Storage Devices
1.44MB 3.5" (A:) : N/A
Hard Disk (C:) : 9.5GB (5.6GB, 58% Free) (NTFS)
Hard Disk (D:) : 57.2GB (20.0GB, 35% Free) (NTFS)
CD-ROM/DVD (E:) : N/A
CD-ROM/DVD (F:) : 452MB (0MB, 0% Free) (CDFS)
Peripherals
Serial/Parallel Port(s) : 1 COM / 1 LPT
USB Controller/Hub : Controller open host SiS 7001 da PCI a USB
USB Controller/Hub : Hub principale USB
Keyboard : Tastiera standard 101/102 tasti o Tastiera Microsoft Natural PS/2
Mouse : Logitech USB Cordless Mouse
Human Interface : Logitech USB Cordless Mouse
MultiMedia Device(s)
Device : Periferica compatibile MIDI MPU-401
Device : Porta giochi standard
Device : SiS 7018 Audio Driver
Operating System(s)
Windows System : Microsoft Windows XP Professional Ver 5.01.2600
Network Adapter(s)
Networking Installed : Yes
Adapter : SiS 900 PCI Fast Ethernet Adapter
Adapter : Scheda Ethernet ADMtek basata su AN983
thx to all
problem with my pc
Usually insufficient CPU-cooling or weak PSU or memory timings too fast for your RAM
Start your PC with FSB133 and monitor temps/PSU voltages via Motherboard Monitor (with activated LOG-function)
Read this :
http://radel.inet.net.nz/m810lmr.html
Read this :
i che with hwmonitor and this is the resultDenniss wrote:Usually insufficient CPU-cooling or weak PSU or memory timings too fast for your RAM
Read this :
temperatures
mainboard 55-60° vpu1 43 cpu2 57
voltages
+12v +12.35 +5v +4.81v core +1.74v(write in red) I/O 3.28v aux +2.50v (red)
i have 300W
Temp look high - please compare the temps from windows with the temps in Bios - seems HW-sensors are a little mixed
5V-line is on the low end - possible cause for instabilities
Better use MBM and use HOT-CPU-Tester to set your system under load - maybe the voltages drop again
with sandra i see this:Denniss wrote:Temp look high - please compare the temps from windows with the temps in Bios - seems HW-sensors are a little mixed
Temperature Sensor(s)
Board Temperature : 39.0°C / 102.2°F
CPU Temperature : 56.0°C / 132.8°F
Power / Aux Temperature : 68.0°C / 154.4°F
Cooling Device(s)
Auto Fan Speed Control : No
CPU Fan Speed : 3342rpm
Voltage Sensor(s)
CPU Core Voltage : 1.74V
Aux Voltage : 2.50V
+3.3V Voltage : 3.28V
+5V Voltage : 4.97V
+12V Voltage : 11.98V
-12V Voltage : 0.48V
-5V Voltage : -5.51V
Standby Voltage : 4.95V
Battery Voltage : 3.39V
Performance Tips
Notice 224 : SMBIOS/DMI information may be inaccurate.
Tip 2511 : Some memory slots are free so the memory can be easily upgraded.
Warning 2541 : FSB exceeds Chipset rated speed. Reduce FSB.
Warning 2544 : System/Video shared memory greatly reduces performance. Use external video card.
Warning 2518 : Mainboard temperature is too high.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
