Hello,
I set up a 19"-server and now I'm going to test it. Everything works fine, so I removed the graphic card(no more space for it) and closed the chassis. But now, the server won't boot anymore (only long-short-short post-code => VGA problem). I have the FIC VA-502 mainboard with the lastest Award bios from FIC. I set the 'Halt on errors'-option to 'no errors', but that didn't help.
What else can I do?
Is the 'VGA-check' also on an older bios version and if, where I can get it?
Regards
Christoph
My mainboard doesn't boot without vga card (FIC VA-502)
Try setting Video in Standard CMOS setup to MONO or CGA, maybe it will help.
