Processor: AMD 2500 Barton Core
Video Card: ATI 9800pro 128
Monitor: Gateway 900vx
RAM: 512mb select ?
HD: Maxtor Diamond Plus9 120 GB (Mast) Maxtor Diamond Plus9 80 GB
OS: XP Home upgrade
Case: Thermaltake Xaser III
Power Supp: 500 watts
Hi Guys I have a big problem that I was hoping you could help me with. I am trying to finish up building this system and almost got there
First I checked the monitor and hooked it up to my old machine. It checked out ok.
I unplugged each hard drive leaving one plugged in vise versa. Nothing
I took my processor apart and checked for any defects, dirt and to make sure that it was making contact with the MB. Also reapplied thermalpaste.Then I had a friend test the processor, it was ok.
I checked and rechecked all the power connections, the light on the MB would come on each time I tried to boot up, but no beep. I even took my processor off and started my MB. The light still went on.
I took out my ram and reseated it after checking it. I also switched slots and tried booting with only one in. Nothing
Each time I tried something different I cleared the cmos.
I unplugged the video card and also took it out. Nothing.
I tried another video card I had lying around with no results.
The power supply works when I turn on its switch.
I know that there's a couple of other things I probably left out, but these are the main things. I would sooooo much appreciate some help and input on this. Thanks a million times....
Dx
