CPU - Intel Celeron 400MHz (128KB Cache) (Installed on a SlotKet)
Motherboard - Unknown (OEM?) Intel i440ZX-ALI513 Chipset (Slot-1)
BIOS - Procomp 03/02/1999-i440ZX-ALI513-2A69KPNDC-00 (B687Z)
RAM - PC133MHz (128MB@2) - 256MB Total
Video - nVIDIA Riva TNT2 M64 32MB
For more info on my motherboard & BIOS, get this PDF from Procomp:-
ftp://ser2.procomp.com.tw/download/b687z.pdf
Background
As it's obvious, I got this low-spec PC in September of 1999. Since then,
I've been modifying it to suit my needs, for example I replaced 64MB
PC100 RAM and installed two modules of 128MB PC133 SDRAM.
Unfortunately, my un-named motherboard has no more memory banks
left to install more.
Last year, I installed a Seagate 80GB HDD ...which my mobo failed to
detect and caused hang-ups at startup. I had to set the 32GB jumper and
Seagate DDO software to enable all 80GB of space for Windows. Things
were running smooth until ...
I found this forum while searching for some hardware info on Yahoo.com.
I had to go through countless of info-laden posts just to satisfy my thirst
for knowledge. Within minutes, I learned that it was possible to get a
modified firmware for my version of BIOS. Strangely, no updates are
avilable from Procomp site. I downloaded Apple's BP patcher and then
patched my original BIOS firmware successfully. Now my motherboard
happily detects all of the 80GB HDD without any extra 32GB jumper. Cool!
The next BIG step
Given the severe limitations imposed by my cramped motherboard, which
has almost no extra features (like hardware monitoring chip, extra BIOS)
to boast of ...the only option left to impove on my computer's performance
is to completely upgrade it with the latest available Intel of AMD solution.
No, it's not! I don't want to throw away my beloved companion for years,
just because it can't take high-speed processors. And, I don't quite feel
like upgrading until and unless the AMD64 platform becomes more afford-
able and more common than it is today. I'm studying for my graduation
degree in Computer Science, and my PC still compiles all my C, Fortran
and assembler codes easily. All I play is "Age of Empires", and my good
old beige box can handle it beautifully, even if it has to order the pesky
TNT2M64 (running at 2x AGP) to fill my 19" 1280x1024 screen.
But ...I sure would like to upgrade to the fastest CPU my mobo can take.
According to the manuals and that PDF, it can only go as far as a P3 550.
However, after scanning the web for the required information, I walked
through a few sites and pages where the description of a Tualatin Celeron
1.4GHz working on a 440BX were given. Though I couldn't exactly got ti
understand the little details about core voltage changings by connecting
the pins etc, I can easily follow all the steps precisely if the situation
warrants so. I'm willing to understand all those tiny details with the help
of which I can make my system run faster than ever.
The help needed
I would like to know if my motherboard can take a Tualatin Celeron or
a Williamette Celeron 2.0GHz or more (easily available). My current CPU,
a Celeron 400, sits on my mobo with the help of a PPGA SlotKet. I would
like to know if it's possible to tweak voltage settings to allow modern
processors to run on a 440ZX. And also, what is the latest and fastest CPU
which can be made to share my beige box with my old, very old, mobo.
Regards,
AgentX
