No access to BIOS (Pc Olivetti M7000 MT/N)-Americ.Megatrends
More detail required.
- Does the machine start up?
- What messages do you receive?
- What key combination are you using to try to enter the BIOS?
Hello, I've the same problem on the same machine.
Thanks for your help.
Yes, until a minimal DOS.More detail required.
Normal boot messages :- What messages do you receive?
Code: Select all
Startup...
Hooking bootstrap interrupt 18h...
Searching for boot record from IDE-0... OKI tried [Esc], [F1], [F2], [F5], [F7], [F10], [F12], [Ctrl]+[S], [Delete] without success.- What key combination are you using to try to enter the BIOS?
FYI : The key to use to get in that BIOS is [SPACEBAR].Yop wrote:I tried [Esc], [F1], [F2], [F5], [F7], [F10], [F12], [Ctrl]+[S], [Delete] without success.NickS wrote:- What key combination are you using to try to enter the BIOS?
fabimaster
barra espaciadora y supresor yo tengo el problema que no me reconoce la ram como hago para que lo reconosca es por el bios o jumpers desde ya gracias desde buenos aires Argentina
SDRAM, PC133 • CL=3 • Unbuffered • Non-parity • 133MHz • 3.3V • 16Meg x 64
128MB maximum * 3 = 384MB maximum total
price ~ $10US/piece
price ~ $10US/piece
