Pentium MMX200 with Award BIOS modular version 4.51PG.
I fitted an PCI 56k internal modem and when I switch on I get the BIOS message: "Updating ESCD... " but nothing happens. In BIOS settings I can not find any option to flush, reset or disable ESCD. Any help?
Updating ESCD.... and nothing happens
You may want to update your Bios to try .
But I believe it's something with PCI compatibility - your Board should have a PCI Bus Rev 2.0 and most never carrds require at least PCI 2.1 or 2.2 and that's not upgradeable .
If you need a Modem use a serial port modem
