startin out in aus
I'm just starting to get inside the box. My computer has a SE44OBX-2 mother board with a celron 333mhz cpu i want to know what the bigest is the cpu that i can put in? i want to get a dvd burner and the guy at the shop said they wont work with any thing less than 2.4GHz
http://support.intel.com/support/mother ... ocsupp.htm
BTW, they BS'ed you regarding the minimum processor support for a DVD burner. I have an 8X DVD burner working just fine with a P3-450 system. Even a P2-350 would work fine.
Our previous system was a Pentium II 350 with a Sony 8x CD Burner, which was fine, although the combination of a slower PC and disk fragmentation meant that it was not always possible to burn at the maximum speed. I wouldn't expect the best performance for CD and DVD burning for PCs around this vintage but I don't believe that they require 2.4GHz+.
