Windows/Linux: Can they run together on the same computer?
Yes Windows and Linux can run on the same machine. But not at the same time.
Its called Dual Boot. And is fairly easy to setup a dual boot system. I would recommend using a second hard drive for the second OS, so that you don't flub up your current OS.
Compaq-Fu Master
