I bought the Kingston hyperx predator pcie ssd a few days ago, and put it on my Asus P6T motherboard in a PCIex16 slot. My system (Windows 7 64 bit is on this ssd. But now every time I boot I get the message: " CD-ROM Boot Priority .. No Medium, Reboot and Select proper Boot Device or Insert Boot Media in selected Boot device and press a key".
Although the SSD is the first priority in the BIOS, which is in AHCI-mode. When I hit a key a few, sometimes several times, it boots OK from the SSD. When I put a bootable CD in my CD-drive, without hitting a key it also boots OK from the SSD. I updated the BIOS to the latest version, but no avail.
This is very annoying, do you have any solution for this?
Kingston nor Asus were able to help me.
Kingston hyperx predator pcie ssd booting problem
What is the make and model of your power supply and how does your system react if you physically disconnect the CD/DVD-player?
It's a Antec TruePower Quattro ATX2 850. I never did physically disconnect my CD player.What is the make and model of your power supply and how does your system react if you physically disconnect the CD/DVD-player?
I think it is a BIOS problem, that's why I posted in this section.
It tries to boot from the CD but fails. So I am trying to get that one out of the mix. I want to see if the board fails to boot from the SSD or indeed the CD is dysfunctional.
I think the problem is that the bios doesn't remember that it should boot from the SSD, but when it boots, by putting a bootable CD in the drive and not hitting a key, it boots from the SSD alright. Isn't there a patch possible to force the bios to boot from the ssd?edwin wrote:It tries to boot from the CD but fails. So I am trying to get that one out of the mix. I want to see if the board fails to boot from the SSD or indeed the CD is dysfunctional.
If the boot order is set then the board should follow it, if not, there's a piece of hardware not cooperating or there's a bug or... the CMOS battery may be low. Replace the CR2032 3V lithium coin cell battery. After you have done that the bios has been set to default settings, so restore the settings you customized before (I trust you noted them down somewhere).
Thanks, I will try that.edwin wrote:If the boot order is set then the board should follow it, if not, there's a piece of hardware not cooperating or there's a bug or... the CMOS battery may be low. Replace the CR2032 3V lithium coin cell battery. After you have done that the bios has been set to default settings, so restore the settings you customized before (I trust you noted them down somewhere).
I did change the battery, a lot of work because I had to remove the videocard, but it did't help. As a workaround I now leave a bootable dvd in my drive.wielk wrote:Thanks, I will try that.edwin wrote:If the boot order is set then the board should follow it, if not, there's a piece of hardware not cooperating or there's a bug or... the CMOS battery may be low. Replace the CR2032 3V lithium coin cell battery. After you have done that the bios has been set to default settings, so restore the settings you customized before (I trust you noted them down somewhere).
AnthonyCopeland
Kingston HyperX Predator will utilize Marvell’s new “Altaplus”88SS9293 controller paired with Toshiba A19nm Toggle Mode NAND.
