my problem is that i can´t find the exactly name of my mainboard.
i know that it is a chaintech board but i want to make a bios update because my new 80 GB HD isn´t running.
Hope someone can tell me the exact name.
BIOS-ID: 01/18/1999-ALADDIN5-2A5KKC39C-00
Thanks a lot to everyone who helps me!
80GB: 01/18/1999-ALADDIN5-2A5KKC39C-00
Using http://www.chaintech.dk/FILES/5xMB/5RSA2A13.EXE,
AWD64GB.EXE wrote: BIOS ID string: 10/13/1999-ALADDIN5-2A5KKC39C-00
BIOS OEM string: 10/13/1999
Searching for size calculation routine...Not found
Searching for SETUP size calculation routine...Not found
Searching for XGroup Block...Found at 72244
Searching for end of last block...Found at 104796
Decompressing XGroup Block...Decompressed 23118 bytes into 33520 bytes
Searching for size calculation routine...is already OK
Searching for SETUP size calculation routine...is already OK
BIOS already supports HDDs over 32GB & 64GB - Nothing to do!
