Hi
I'm trying to install a new 60gb hard drive into my computer but it seems it doesn't recognize it , why?
Can u help me please?
ps: I have an amibios v1.95 20/05/00
60GB: 61-0520-001169-00101111-071595-440BX/ZX
MSI board. www.msi.com.tw
Its model number should be silkscreened on it.
Anyway, with a BIOS as recent as yours, support for large HDDs must be there. Try to enter the HDD parameters manually in BIOS.
I'm just saying that an AMI BIOS of 5/2000 "should" have large HDD support (perhaps even larger than 64MB). But if you still have problems, I pointed out how to identify your MSI board model, so you could proceed with the flash update.
Not 64GB?ajzchips wrote:perhaps even larger than 64MB
The latest official BIOS I could find for V1.2 is 2.9. This does not support large disks. A patched version which you can test is posted at the URL in my signature.
Remember:
- you flash at your own risk
- read and follow the flash utility instructions.
- please let us know how you got on via the Wim's BIOS forum.
- you may need to run the HDD manufacturer's utility to reduce the transfer rate of a UDMA66 or UDMA100 drive to UDMA33. See the post "links to ATA mode setting utilities" in the "Collected Wisdom" forum.
Remember:
What's your Bios revision number ?
You should see a A6119V1.3 or similar message on the same screen with the Bios-ID you posted but in the upper left corner .
Is your MS-6119 installed in a Fujitsu-Siemens or Maxdata or other manufacturer's PC ?
1.3 is the last AMI BIOS posted on the site and is dated 1999-3-24. If yours is dated 20/05/00 and is version 1.95 then it looks as though it has been provided by someone else - OEM ? Hence Denniss's questions.Innercity wrote:Should I upgrade to p2.9 bios at the msi site or can I live my computer with my current bios?
Is there anyway to solve my problem coz I kind of new in this stuff and I don't want to take risks
10x
MSI provided both AMI and Award BIOSes and there seem to have been more updates for the Award BIOS - maybe not so well written
