Need BIOS update for this so I can install a new 120 GB hard drive.
Thanks!!
Kim
120GB: 693-686-6A6LGJ1CC-00
Is full ID (from BIOS Agent or similar) something like:
bios id 12/21/00-693-686-6a6lgj1cc
bios eval v.bn693x b02 12-21-2000
Original BIOS at http://www.zdnet.de/treiber/man_prod/bo ... os-wc.html? Need the "bn693x" or similar to identify the board if it is the Bona OEM version of Jetway.
An Award 6.00 Bios with this date should support at least up to 128GB
What's the problem you have ? > Detected as 32GB ? > Remove 32GB Limitation clip on your HDD
Plesa press "pause/Break" Key on your keyboard on the first screen with your Bios-ID an look in the upper left cornber just below the Award Logo - the needed Info should be there
It will only say "bios eval" if you used something like BIOS Agent as I suggested. As Denniss says, look at the top left of the memory count screen under the Award logo. Or use BIOS Agent.kimical wrote:I don't have anything similar to bios eval v.bn693x b02 12-21-2000
Try using the WinME version of FDISK/FORMAT from www.bootdisk.com
