Have an Iwill BD100+ MB and new WD 80G drive... Latest Bios from Iwill's site is 12/12/00... They quit updating the Award Bios after that. The BIOS won't recognize the HD...locks during auto-detect... Can skirt around it by jumpering the HD, but the stupid overlay loads after setting up the drive.... I can remove the overlay using the drive utilities, but I'm afraid that will cause issues. Here's the full scoop on the BIOS.... (O/S is 98SE)... Any ideas?
Date: November 10, 2003
Time: 23:06
Enhanced Disk Drive
Specification : BIOS currently supports this feature
DMI Version : BIOS supports minimum version 2.2. Latest is
version 2.3
ACPI Version : BIOS currently supports latest version 1.0
BIOS Chip in Socket : BIOS currently supports this feature
Supports LS-120 Booting : BIOS doesn't support this feature
Supports ZIP Booting : BIOS doesn't support this feature
Supports Network Booting : The testing of this feature is not supported by
the current DMI version
BIOS ID : 12/12/2000-i440BX-W977EF-2A69KI3IC-00
BIOS Date : 12/12/00
BIOS OEM Signon : BD100Plus/31311A (Dec.12.2000)
BIOS ROM Size : 256K
Chipset : Intel 440BX/ZX rev 3
Super I/O Chip : UMC/ITE 8669 found at port 108h
Thanks and Regards,
John
80GB: 12/12/2000-i440BX-W977EF-2A69KI3IC-00
It's a tricky one....our normal patcher does not like it.
However, the BIOS does not seem to be the real issue; bp does not find any bugs.
Code: Select all
D:\Hardware\Iwill>..\award\awd64gb bdp1212.bin
AWD64GB.EXE - Award BIOS patcher for HDDs over 32GB & 64GB v0.9
Copyright (c) 2002 Rainbow Software (http://rainbow.ht.st).
Searching for Main Block...Found at 131072
Searching for end of last block...Found at 215321
Decompressing Main Block...Decompressed 84245 bytes into 121748 bytes
BIOS ID string: Error #100: Disk read error.Code: Select all
D:\Hardware\ROM>bp-4rc71.exe bdp1212.bin
BIOS_Patcher ver. 4.0_RC.7.1 from "Second_Hope utils".
Warning! It is only test-version and recommended only for power-users!
Found 2Mbit BIOS (4.5x)!
"original.tmp" - MAIN_2 part Warning! Tiled BIOS!
(cpu_names) 1. : -> fixed.
(old_P3) 2. : not request to fixed.
(koefs) 3. :> -> fixed.
(32g) 4. : not found.
(32g-2) 5. : not found.
("MB") 6. : not request to fixed.
(1000MHz) 9. : not found.
(koef>9.5x) 10.: not found.
("genu") 7. : not request to fixed.
(L2-init) 11.: not found.
(new_freq) 12.: not found.
("Y"/"N") 13.: -> fixed.
UDMA for "big"-HDD on UDMA33_only_MB fix: not found.
CBROM V2.07 (C)Award Software 2000 All Rights Reserved.
[CPUCODE] ROM is releaseCBROM V2.07 (C)Award Software 2000 All Rights Reserved.
Adding modul.tmp 27.4%
Adding start.tmp 87.5%
Adding reall.cod .... 55.9%
if you can`t see all messages - choose 80x50 mode or run with ">report.txt".
(c)2002 apple_rom, www.ROM.byTested patched BIOSes. Untested patched BIOSes.
I'll pull the HD and try the default jumper setting again... Always a chance I didn't have it jumpered properly when I originally tried to install it. The jumper workaround WD uses forces the drive to report itself as a 32 Gig drive to fool the BIOS into accepting it. It may well be that's why the drive is still working without the overlay.... Without the overlay, both Win 98 and DOS have no problems/corruption issues with more than 32 Gigs of data loaded on the drive.
Thanks,
John
Thanks,
John
Just for information... There is already v4.23 available from bp.NickS wrote:Code: Select all
D:\Hardware\ROM>bp-4rc71.exe bdp1212.bin BIOS_Patcher ver. 4.0_RC.7.1 from "Second_Hope utils".
Tried the HD again, this time with the jumper removed, and the BIOS recognized the entire 80 Gigs... Believe I had it jumpered wrong when I originally tried it out...... So chalk it up to Basic Operator Error on my part. I'm also fairly impressed that a four year old MB supports a larger drive... The first HD I ever tried with it was only 5 Gigs, so I've come a long way...
Thanks for your research--gave me the confidence to try again.... Certainly is better than running with the overlay...
Regards,
John
Regards,
John
Thanks....cannot open that site at presentsulbert wrote:just for information... There is already v4.23 available from bp.
It happens to us all, believe me. Glad you got it up and running.cactus521 wrote:Tried the HD again, this time with the jumper removed, and the BIOS recognized the entire 80 Gigs... Believe I had it jumpered wrong when I originally tried it out...... So chalk it up to Basic Operator Error on my part. I'm also fairly impressed that a four year old MB supports a larger drive... The first HD I ever tried with it was only 5 Gigs, so I've come a long way...
