i have a board 04/08/1998-i440LX-Ali513-2A69JM2GC-00.
On my old hard disk, i can enable DMA under win98se.
On my new disk, Seagate 20Gb UDMA5, DMA cannot be
enabled. can anyone help me? also i need a patch for
the 32gb limit. thanx in advance
2a69jm2gc : DMA does not work on win98se
The non-working DMA is because there's a Bug in your Bios - it tries to enable UDMA Mode 5(UDMA100) despite the chipset controller is only capable uf running UDMA Mode 2 (UDMA33)
Get an UDMA tool program from Seagate and limit your HDD to UDMA33 and DMA will be available
1 Google hit for that ID at plasma-online identifies that as Kamtronic/TMC AI6NEL-E1-0421i440LX-Ali513-2A69JM2GC
There's only 1 BIOS archived for that, at:
http://web.archive.org/web/200109100152 ... i6nel1.exe and that appears to have a problem.
PKSFX: (E03) D:/HARDWARE/TMC/AI6NEL1.EXE - error in ZIP use PKZipFix
OK, PKZIPFIX fixes that. The BIOS file inside is:
AI6NEL-E1-0421
which is the one you have already.
It appears to support HDD up to 32GB and be patchable for more:
AI6NEL-E1-0421
D:\Hardware\tmc>..\award\awd64gb AI6NEL1.BIN
AWD64GB.EXE - Award BIOS patcher for HDDs over 32GB & 64GB v0.9
Copyright (c) 2002 Rainbow Software (http://rainbow.ht.st).
New-style code found at 3560
=> 32GB bug patched successfully
Searching for size calculation routine...Found at 1473
Searching for free space...Found at 10753
Patching code at 1472
Searching for SETUP size calculation routine...Not found
Updating checksum...Located at 114686...Updated OK
