I have problem with HD & CD detection
Program: eSupport.com BIOS Agent Version 3.30
BIOS Date: 03/11/99
BIOS ID: 03/11/1999-i440BX-W83977-2A69KA1EC
OEM Sign-On: GREEN AGP/PCI/ISA SYSTEM
Chipset: Intel 440BX/ZX rev 3
OS: WinME
CPU: INTEL(R) CELERON(TM) 333 Mhz MAX: 400 Mhz
BIOS ROM In Socket: Yes
BIOS ROM Size: 256K
Memory Installed: 128 MB
Memory Maximum: 768 MB
Memory Slot 01: 64 MB
Memory Slot 02: 64 MB
Memory Slot 03: 0 MB
??GB: 03/11/1999-i440BX-W83977-2A69KA1EC-KG
Abit BH6
http://www.abit.com.tw/
Check your mobo to find out whether you have the standard BH6 or BH6 V1.1
Last two digits of your Bios-Id are missing - they work as Bios version identifyer at Abit .
According to your Bios date and your "standard BH6" meaning BH6 1.0x your two ID letters should be KG
http://fae.abit.com.tw/eng/download/bios/bh6.htm
What's your full Bios-ID ?
-> Note the last two digits and you should find them listed in the BH6 1.0x Bios List .
Then use the latest available Bios but please read the update Guide at the site there before flashing !!
I don't get it!
BIOS Date: 03/11/99
I have this and sticker on bios chip "AWARD 1998 PCI/PNP 686
159763834
What is full BIOS ID? Were to look for that? Sorry I'm litlle bit confused, don't want to make mistake.
BIOS Date: 03/11/99
159763834
would be the full ID you see when your machine starts up at the bottom of the screen.
bh6ss.exe woudl be the upgrade to use in that case.
