40/80GB : 11/19/97-i440LX-SMC67x-2A69JSWAC-00
It's possible you have to disable UDMA5 mode on that 80GB Maxtor. They have an utility to do that. The bios thinks the chipset can handle this mode but it cannot...
FrenchUser
- BIOS Newbie
well
how can I do this ?
I've found utilities for downgrading ATA100 drives to ATA33, but nothing about UDMA5, and nothing for ATA133 drives
I can also disable UDMA in the bios, then i will see thaht with the drive who must work on ths motherboard
thanks
how can I do this ?
thanks
Apple_rom's patcher bp which I used on this is supposed to fix the UDMA problem, so it will be interesting to see if that is the issue.edwin wrote:It's possible you have to disable UDMA5 mode on that 80GB Maxtor. They have an utility to do that. The bios thinks the chipset can handle this mode but it cannot...
@French: The 3-times memory test is not a bug, it's a feature writing different test patterns and as you cleared the CMOS I guess that is the default. You found the way to get around it, anyway.
The same utility which changes from UDMA100 to UDMA33 should set the maximum transfer rate for the UDMA133 drive as well; I believe the command set is the same in ATA5 or ATA6.
FrenchUser
- BIOS Newbie
no more problems
i've installed Mandrake 9 and windows 98 on a Maxtor ATA100 60go
and today i'm testing with a Maxtor DiamondMax 8 ATA133 40 go it seems OK
you can add this bios to your list of succesfully moded bios
thank you very much
old and latest hardwares are not a problem with Nicks
thank you very much
FrenchUser
- BIOS Newbie
