IWill P55XU BIOS Update
Oerg
BIOS Rookie
G'day y'all,
I'm looking for a BIOS update for the IWill P55XU Socket 7 ATX board.
Board version: P55XU Ver1.21 (Nov.06.1997)
BIOS String 10/30/97-i430TX-ALI513x-2A59II3BC-00
Iwill ftp and website are defunct. Archive.org shows newest BIOS:
P55XU All Ver. (or Product No:31030A) ,BIOS Date Code: Jul.21.1999 (159KB)
Which links to http://support.iwill.net/attention.asp? ... xu0721.exe
But this is not archived, so the file xu0721.exe is missing.
Any help would be greatly appreciated :)
Cheers!!
Eric
Oerg
BIOS Rookie
Thank you :) When I get home later today I will immediatly try it out.
In correlation with the other thread, if my 40GB HDD still doesn't get recognized, then I'd like to ask for this bios to get patched ;)
Cheers!
Eric
Oerg
BIOS Rookie
Edwin deserves a free virtual beer :D
Uniflash didn't work. Flash errors on last two... thingies (blocks represented by onscreen chars). I quit and used AWDFLASH just in case.
The flasher crashed and caused a soft reset but *after* the flash had completed (thank god). As you can see, it works. and the K6-II now gets recognized as such ;)
The bottom drive there is the 40GB HDD that hadn't worked before. The BIOS *does* do good :D
To say in your native tung: Dankjewel!
Cheers!
EDIT: Some random anecdotes:
11:02:10 AM Oerg866: aaah. That's better
11:02:21 AM Oerg866: L2 is now recognized by BIOS (memtet still says unknown but who careS)
11:02:26 AM Oerg866: L1 now has 2GB/s, which is good
11:02:34 AM Oerg866: SDRAM is 9MB/s faster now
11:02:37 AM Oerg866: I like this BIOS :)
Thanks, I think you want to replace the cmos battery if the flash action is a bit flakey, they do need to be replaced every now and then (after a period between 3 and 10 years depending on the quality). Good to see I saved a board from the bin.
Oerg
BIOS Rookie
It's good, I measured 2.98V on it :)
And, well, the board is fully functional in either case, so i wouldn't have binned it.
Thanks!
Oerg
