My bios is unable to detect a 40 GB HDD. It detects 20 GB without problems. Please help.
Anand
40GB: i440ZX-W977-6320M100C-HL
Looks like A-Trend 6320. I can't reach their site at the moment, but the latest BIOS Riascorp has at http://www.riascorp.com/pc_solutions/bios.html is:
05/05/1999-i440ZX-W977-6320M100C-DW
with message
6320M VER:1.0r03 WB1
. I can patch and send that one...
(update)...done.
with message
(update)...done.
@ajzchips: Errrrrr....yes. I ignored the last two characters in the search.
Maybe he could have posted his full BIOS string as requested in the FAQ and posting rules and I'd have noticed the date.
BTW, has A-trend disappeared ? as I can't get to the site at all.
@anand: If you'd like to save your existing BIOS using AWDFLASH and email it to me or ajz one of us will patch it for you.
All Atrend's BIOSes are available at mirror FTP ftp://ftp.univ-lille1.fr/pub/vendor/atrend
I was having trouble reaching either mirror site. I'll try again later...Rainbow wrote:All Atrend's BIOSes are available at mirror FTP ftp://ftp.univ-lille1.fr/pub/vendor/atrend
Yes, I can see the lille mirror site now. But the 6320 BIOS at that site is the same version as at www.riascorp.com, so I'll see if anand can send a later one.
Well, when the PC is switched off the BIOS is not running so the RTC keeps the time. When the PC is switched on the OS is running. I don't see how the BIOS could affect the RTC's timekeeping - has anyone else any ideas ?In an email, Anand wrote:Thanks for your help Nick and sorry for not replying earlier.
I did patch the BIOS but a funny thing happenned. After I patched it, the clock started to lose time. I don't think it is a problem with the CMOS battery because this happenned immediately after I patched the BIOS.
Is it OK if I go back to my old BIOS?
He can go back to the old BIOS but of course he would need to use Disk Manager/EZ-Drive or similar, or restrict himself to 32 GiB.
planetcare
Same problem,how do i back up it i downloaded some bios of the same company, plus i tried backing up the bios before doing anything now after doing the backup using
awdflash /sy /pn
then when asked i provided backup..bin
after that i can hardly use the computer it automatically shuts off i didnt even update the bios how can i fix it and i want to access my 40Gb HDD on that please guide me how do i do it and which update should i use
awdflash /sy /pn
Try with the downloaded file name:
awdflash xxxxxxxx.bin /sy /pn
planetcare
Tried that no use
any other option
let me know which version should i update my current bios with,
and how do i do it
through awdflash or should use something else
any other option
and how do i do it
Please provide clear details of what your computer does now.
planetcare
I got that fixed,,
i would have to have the update for my bios
Mother board details
manufacturer A-Trend
model ATC-6320M
Award Bios
String ID i440ZX-W977-6320M100C-HL
can anyone help me with the excat update for the bios
i cant seem to find it..
and please provide me the details to update it
just in case
Thanx for ur cooperation
really admire that
model ATC-6320M
Award Bios
just in case
really admire that
Incomplete data.planetcare wrote:manufacturer A-Trend
model ATC-6320M
Award Bios
We need something like that:
OEM Sign-On: 6320M VER:1.0r03 WB1
BIOS String: 05/05/1999-i440ZX-W977-6320M100C-DW
planetcare
I hope this is what u need
MANUFACTURER : A-Trend
MODEL : ATC-6320M
This is what I have Excatly on my Screen
Award Modular BIOS v4.51PG, An Energy Star Ally
Copyright (C) 1984-99, Award Software, Inc.
6320M VER:1.0r02 WB1
PENTIUM III CPU at 450MHz
Memory Test : 65536 OK
Award Plug and Play BIOS Extension v1.0A
Copyright (C) 1999, Award Software, Inc.
Suggested SDRAM CAS Latency TIme is " 2 "
Detecting.
At the Lower End of the Screen I got
Press F1 to Continue, DEL to enter SETUP
Is that what u require cause that is all i got on my Screen i dont have any kind of date along with the BIOS String, i have the computer on and i copied all this as I got the computer booted and copied everything and the screen is still in front of me.
hope that is what u need to know ..
I need 40GB Support on it, when i try to detect it the computuer hangs up and nothing works... i tried manual detection too no use...
can anyone help me with the excat update for the BIOS i cant seem to find it..
just in case
MODEL : ATC-6320M
Detecting.
just in case
