Hello there,
I need a patch for soyo SY-6BA+. Your reply is a great help. Thank you very much.
Neil
I suggest there's another reason you can't see more than 33 GB. The BIOS already appears to be OK.BIOS ID string: 07/11/2000-i440BX-ITE867-2A69KS2IC-00
BIOS OEM string: 6BA+_2DA2
Searching for SETUP size calculation routine...is already OK
BIOS already supports HDDs over 32GB & 64GB - Nothing to do!
