I have a 40GB Seagate harddisk
The problem is I cannot get this drive to work on my Biostar M6Vbe with the latest bios.
Maybe it was the 32GB Bug...
Does anybody have any hints...?
Does there exist a BIOS that supports harddrives of the size?
thanks in advance,
Don Promillo
40GB: Biostar M6Vbe
There's a patched release here: http://http://wims.rainbow-software.org
Warning !!!
The patched Bios is only for M6VBE with VIA 82C693 Northbridge !!!
There's an older one existing with VIA 82C692 Nortbridge .
Please verify first - big VIA chip in center of board .
And please post your Bios-ID including OEM-message in top left corner just below Award Logo on the screen showing the Bios-ID on the last line !
I have seen 693 versions with 692 in it's Bios-ID (07061999 Bios) so not always helpful .
With this special board it's better to have a look onto the VIA chipset .
I have seen many cases witht this board and a bad flash due to version confusion .
Don Promillo
- BIOS Newbie
My Northbridge is a vt82c596a
Can I use the Bios at http://http://wims.rainbow-software.org which has the Id: 11/18/1999-693-596-8671-2A6LGB09C-00 M6vbe with Via693 Northbridge???
Someone already said that's the southbridge - what is the other chip ?
Don Promillo
- BIOS Newbie
My Northbridge is a vt82c693. I have installed the Nios Update from http://wims.rainbow-software.org (vbe1118a)
I tried a 80GB HDD, but there werde only 32GB recognized!
Untested Boises are good, too!
Thanks!
Thanks!
Don Promillo
- BIOS Newbie
Yes, i checked the settings, but it doesnt works! Only 32GB...
"Detecting Primary Master" is recognized, but in the 2 frame : "UDMA 100... and then freeze!
Cleared CMOS after update?
Don Promillo
- BIOS Newbie
No, i does´nt clean my cmos... I try it and report!
How i use the tool from the HDD manufacturer.
I install the programm normally in the windows and don´t Have got to do new partitions on my Harddisk? Because i dont have enough room for 80GB...
Model : IC35L080AVVA07-0
Thanks!!
Thanks!!
Don't use any software from manufacturer. Run FDISK and create the partition(s) you want, reboot and then format it(them).
